bump stops??
hi guys
im soon to be fitting eibach springs and kyb shocks! :D
with regards to the bump stops do i shorten then 0.8 inch to match amount to be lowered by?? obviously you dont want to remove all together but also dont want to bottom out too early!!!
regard steven
No, leave them as they are. Bump stops are that height for a reason. Good springs and shocks shouldn't bottom out anyway under normal conditions.
i must admit bumps stops are very short on these as they are!
im used to working on vw's which need cutting down when lowering 40mm else you hid them over small bumps all the time!
