flow testing
Does anyone know if £15 an injector is a fair price for flow testing?.
If that is flow and cleaning that is ok, I think andyp had a contact that did them for a tenner!
Hi Mark.
Its just for a flow test.The injectors are new.Done a silly thing a while ago and bought venom injectors before i found out they have a terrible reputation.would buy some nismos but ive spent £2500 on other tuning gear.figured if i get them flow tested to check they will flow 550cc then i can fit them and replace them at a later date.
£15 cant be to bad dude, i seen someone on the sxoc pay £50 each injector ouch he will be glad it was a 4-pot :)
Oh well then,in for a penny in for a pound.its never ending mate.new ring gear.head work etc.mind you i did get the block bored and crank polished for a steal Lol!!!! ;)
Bud do yourself a favour and get some decent injectors or you could be forking out for a new engine, and if they aren't 550 you will have to pay for a custom map!
I know where your coming from.if they dont flow right then im not using them.cars are a bottomless pit.thank god i dont have to pay for the engine build as im a mechanic and have built two zed engines before.my wallets going to casualty soon after the hiding im giving it!!!!.
Change the o-rings that they come with, the two most common problems with the Venoms seem to be conistent flow rates and the o-rings leaking. So If flow rates come back ok, and you have changed the o-rings you can feel a lot more assured.
Thanks for the tip Dave.set of seals and a flow test it is then.wish id never bought the sodding things now !!!.
