is it possible to turbo a n/a zed ?
is it worth it ?
is it just cheaper to buy a twin?
your thoughts are very welcome
the earlier z31 was a single turbo i was wondering if this same setup could be used on our engine. it means a custom fabricated exhaust manifold . the techies will be along shortly.
is it worth it ?
Unless you have the convertible (which was N/A only from the factory) then don't bother.
It can be done - Topless did with his convertible but if you have a targa or slick-top then just sell it and buy a twin turbo. It's not worth the conversion cost and the car will not be worth any more for it.
Richard :smw:
TO convert a NA to a TT it's about £2K labour plus the parts - you could get a crashed donor car for about £1500 and sell what you don't use.
Still looking at £3K +++++++ unless you can do the job yourself.
It's not worth it unless there's a special reason (ie you want a convertible TT).
okso are the engines the same apart from the obvious turbo ecu ect becouse i was told the supra n/a is a weeker and drasticly diff engine from the turbo beast so can the same be said for the zed?
wouldnt really bother buying an na and turbo'ing it, just get a tubby there is plenty out there to be had, just be wary though
Richard :smw:
aint actually seen topless's car, anyone got any pics
what do the twin turbo zeds use for tuning software my honda can us an eprom and a program called crome which i can update on the road while someone else is driving ?
N/A to turbo .....no not worth it ......
had a look at that too but ,,NO .....so that's why i have NOS ......
Zemulator :)
http://www.ashspecz.com/ashspec/zem/zem.htm
iv carried out a complete NA-TT conversion, and to be honest buy one from the start, you can just fit a set of Turbos, manifolds, intercooler/pipework upper water feeds, lower oil block feed and sump, and then run low boost/high compression, run without wastegate solenoids and fit a boost controller. Will still be quick due to the compression ratio. but limited on injectors, fuel pump, internals
i thought the valves were different on an na also????????
you can still use NA heads, just a bit restrictave and major porting is required to even get a match of a TT head
for a true TT conversion you would use a TT block and pistons more suited to running higher boost.
but your right the exhaust valves are stronger on a TT made of iconel i think
