Just been thinking (ohhherrr) anybody thinks about this idea, Cutting the tension rod bush housing off, then machining a thread maybe M16 or M20 depending on diameter of the shaft, then screwing a rod end bearing on female type to suit......then spacing the bearing in the middle of the lower arm with ally spacers or something alike.....
What do you thinks peeps...
cheers Jon...
