nipple removel
Sorry prev's ;) :rofl: :rofl: Just snapped off a bleed nipple on my run around. Am i right in thinking that you can buy a bolt type thing that will screw into the nipple hole with an anti-clockwise turn, bite and then remove the part of the nipple that is in the caliper.(not sure that makes sense????) or is it a drill and re-tap job
thanks graeme
Soak the sheared off nipple with Plus Gas overnight and then try heating up the area around it with a blow lamp before you attempt to remove it with the stud extractor. Get it properly hot without setting fire to anything (like piston dust seals etc). Good luck - you WILL need it !
