revs rise in Neutral
hi cleaned all connectors etc etc
taking to be plugged in on the weekend
car 5 times out of ten stalls when put into drive you can just keep it going but it surges forward as you have to rev it
drives lovely when moving
but when in Neutral only it ticks over at 2k rpm? its not a sticking throttle etc etc
ta
chris
you learn something every day why would that make it have the above symptons
ta
chris
Sounds like the FICD (Fast Idle Control Valve) is not working (either bad connection or faulty valve - more likely connection). Also sounds like someone has raised the base idle to try and overcome this. Do the revs pick up when you turn the aircon on? And go back down when you press the "Econ" button on the aircon control unit?
from memory yes but I can go and check
where is the FICD
would that make it almost stall in drive
Yes its there to increase the revs to stop it stalling when the box loads up. Increase should be ~150rpm...
Next to the idle valve at the rear of the pleum, passenger side. Grey connector...
found it beneath a load of other things shall have to do it later in the garage
putting the AC on doesnt seem to make the revs rise as its ticking over at 1500rpm anyway
Should still increase the revs at no throttle as it lets extra air in... Once this is sorted you need to adjust the base idle. Alfo has done a write up in the FAQ setion on that :)
