i got 2 bov's with my car and all i have is the BOV..(ctt works-brand or summit like that) i dont really know what else i need...seems no-one in bournemotuh area knows what they are talking about!
i want them fitted by wednesday so where do i start? :cry:
Never heard of those.
If they haven't got a fitting kit for the Z then it's going to be a long job.
Either get some hard pipes made up to fit them in front of the throttle bodies or you'll need various parts to mount them in place of the factory recirc valves...
You might be better selling them on eBay or something and getting a set with a fitting kit.
this is the one's i have they are 'tcc work type III' i cant find a decent instruction manual anywhere on the net!!
If you look under the headlight pannel , below the air intake you will
find two silicone tubes either side with bung caps. One is a take off after the
intercooler( I cant remember which it is tho. you can feed the bovs off of
these pipes IIRC
Allan
Not quite seeing the problem here, maybe I'm missing something.
Just remove the stock re-circs, put the bovs in place, attached the vacuum lines, and plug-up the places the return hoses would normally go.
I used the rubber bungs you get at the bottom of old ladders, lol, but you'd find something similar at the end of brush handles etc.
D.
D.
i found what i need..there are 3 tubes right...2 big ones and a little one. the little one obviously fits on to the valve but out of the two others which on do i put on bov? also as seen in the pics posted.. i dont have the metal tube as shown in the pic (the end with the screws) so will be needing that..i guess!
Do you have a picture of your bovs?
Then we'll know what you need.
Also, does your car still have it's stock Recirc valves? The re-circ valves are pretty much just bovs, but instead of sending the boost out to atmosphere (and making a cool noise) they feed back into a hose, which eventually goes back into the intake system.
its the one in the pic from granpa (above) yea found the recirc..im gonna try it tomorrow for our weekly bournemouth car gathering lol wish me luck!! just need to make sure i bnung up the right hole lol
cheers :hyper:
the one you block off is the smallest diameter pipe except for the vacuum pipe on the valve lol
