smoking a lot purp
had z off road last month and when i put it bak on the road on sat i knew it had a small oil leak in to the drivers side turbo (smoked slightly when first started) but when i went out in it on sat it was belching smoke out for a bout a mile but after it had got warm it was fine must have just with it been stood for a month and just been moved around not getting warm but i shat my self when i set off there was a smoke screen following me looked like an F1 car that had blown up but its ok now av to get it sorted though soon
Sounds more like a valve stem seal to me... The smoke on startup after being sat overnight is caused by a very small weap in one of the seals, allowing oil to dribble into one of the cylinders overnight which must then be burnt off on startup hence the smoke. As your car has been stood for a month the seals will have hardened slightly and so will not have been sealing as well. This will cause the clouds of smoke you were seeing especially as one of the seals was already going. After a time the seals (not always) soften up again as they are warmed up...
CheerZ,
Andy
