Silicone Cooling Hoses Needed
Anyone know where I can get some silicone cooling hoses, I need the small hoses (not the big radiator ones) As im doing the water pump and i wish to replace all the small hoses as they are going to become a pain in the arse later no doubt. So if someone could direct me to a site where i can purchase some i would be most grateful.. Don't want to spend too much on them
Unless you want silicone these can be obtained from Nissan (local main dealer) for about £4 each...
Depends which hoses it is exactly.
If it's one of the many under the plenum then you can strip all these out and make it much more reliable for the future.
They're only needed to keep the plenum warm in cold climates IE north pole LOL
Do a search for "water bypass" for more details.
Some of the others can then be swapped for standard water hose from any car spares place.
The small hoses near the water pump are Nissan parts from your local dealer or try MJP in the traders section.
They're not much.
It'll be the ones above the water pump behind the upper metal coolant hose you're after. Nissan only part, part number 14055-F6511. 2 required, available from MJP in the traders section.
