Need help with traction control.....
First of all cheers to Sarre who plugged his laptop in on Sunday and had a look at the settings. The only problem I have now is the reference for the driven wheels.
I never wired it up as SWM1's site I followed the instructions provided with the unit, I bought it second user from a forum member who had a 91 UK Manual Car, mines a 93 UK Manual. So It should be right, but I noticed on sunday night that looking at his various setting on my PC his driven wheels differ on his backed up dat files. This leads me to believe it requires calibrating but I didn't receive the calibration tool. Anyone know how to do this without the calibration tool, as the rear wheels are LSD and would turn together so can't really follow the manual? anyone know where I can get this device from?
This is how its wired to the abs computer.
PIN 6 LIGHT GREEN GOES TO RED FROM THE RLTC.
WHICH IS FRONT LEFT SENSOR.
PIN 11 BLUE GOES TO BLUE FROM THE RLTC.
WHICH IS FRONT RIGHT.
PIN 8 BROWN GOES TO YELLOW FROM THE RLTC.
WHICH IS REAR LEFT.
PIN 24 ORANGE GOES TO GREEN FROM THE RLTC.
REAR RIGHT.
Bit long winded, sorry
ABS Wire Traction Wire
Light green = Front left Red = Channel 1
Blue = Front Right Blue = Channel 2
Brown = Rear Left Yellow= Channel 3
Orange = Rear Right Green = Channel 4
We need to hook it up again to check the settings. I used the instructions on TT.net to install mine so our wheel settings will be different.
You can set any channel to any wheel in the programming interface. Using the laptop graph part of the program. Hard acceleration the two fastest wheels are the back. Slow sharp turns the slowest two wheels will be the inside.
Well I can get acess to a laptop with a com port on at 6am tomorrow morning (dropping a guy off after night shift) I was just about to do the jacking up and spinning of the wheels and the green light wont work (comes on at start but nothing else) so I cannot acess diagonistics mode as I think we have left the data logging box ticked :rofl:
I have wrote some settings into the program on the desktop pc that I remembered from sunday.I will transfere these over when I get my wheel sensors sorted. Lets see if I can upload the dat file........just rename it from .txt to .dat
p.s. mine does seem to be wired up same as your stuart.
Well the guy in work had a laptop with a monitor connector at the back :rolleyes:
