lambo rear lights
Hi Guys,
I would much appreciate some help on a couple of questions.
i am in the process of fitting the lambo conversion from zcentre. I had to modify the brackets to bolt the panel on to which is no problem - but have noticed that the gap at either end is about 5mm each side. do i need to fill this or once bonded and bolted just leave it. The panel also is proud at the bottom about 3/4 mm - what is the best way to get this to sit flush without damaging the panel. I am assuming that the wiring is straight forward. I am working long hours at present in an area with no mobile signal so cant really try luke - just wandered if anyone had experienced the same and overcome these problems. Any help much appreciated as ever
cheers
my lights are just bonded, had to cut the centre mounting for the stock lights out and the venum lights i have dont come with any type of fixing.
cant you bend the lip that the sealent goes around in a bit with a pair of pliers wouldnt have to be by much just to get the lights flush, seems the logical thing to do to me. If you click on the little car symble on the left of my post you can see the rear of my car and the gap i have either side i just bonded the lights making an even gap all round, i take it you are using some sort of bonding sealer too?
thanks mate i will give that a try - i will be using tigerseal to bond and seal. Having no experience with fibreglass i was unsure whether it would bend or would just crack and split (the latter knowig my luck).thank sagain
