Gasket or hylomar
What do people use when putting the front two water pipes back on, the ones just below the pulley covers with the sensors in. Is there supposed to be a gasket behind these or do you use gasket sealant and if so which 1 ? I think mine have been leaking behind these although I am replacing the two rubber hoses there as a matter of caution.
I got some proper sealant that is coolant resistant from halfords.
ย
I've used hylomar before and it leaked in a few weeks, (just what I had lying around at the time)
The silicon type gasket sealer works perfect :dance:
Hylomar is only good for ''stagging'' gaskets!-crap on it's own! :wack:
Thanks guys, I think I used hylomar last time I put them on and it has sprung a leak. Will try some better stuff this time around !!!
I have used RTV sealant on all sorts of things, even guttering. Its good enough for Duetze engines and Cummins, but there is no excuse for not using a gasket, the rest is just a belt and braces.
