Zx Tt Not Starting???
Hi there folks,
Can some one help me? i have a 300zx tt which has been running fine until today, the car just wont start, i used to start the car daily and then did'nt bother for 3 days and when i tried today just did'nt want to start (its not fuel or the battery). Any common faults for this time of the year? any ideas??
You're input would be greatly appreciated,
Is it turning over and not firing, or is it not turning over?? as above need more info.
If it's the first i just had that, and a change of spark plugs from smithy cured it and now she fire's up nice and purrs like a content kitten!
Neil
Hi Fellas,
Thanks for replying so quickly,
The car does try to turn over, the fuel pump does work (you can hear the pump kick in), i have just changed the plugs (platinum) and had a service litterally 1 month ago but it still does'nt start? Are there any other fuse boxs other than the one in the engine bay??
Hope this helps.
Neil
There is a fuse box in the drivers footwell.
Not sure what fuses are in there though.
Darrell
I find these flood very easily,could be your ''sudden'' problem. :)
Thanks fellas,
Problem solved, it was the plugs flooded.
Oz
buddy, what have you done now after you found this. Just wondering
[sIGPIC][/sIGPIC]
to solve that you remove the plugs and dry them off, also helps if you warm the plugs up with a hear dryer etc then stick them back in a hey presto :dance:
