is there anyone on here that can help? engine internals
i am going to try and make my own engine internals ie rods,pistons and so on i have access to all materiels and machines i need to do it but i need the actual specifications of the h rods and forged pistons and so on is there anyone that would have this on here if possible please
your best bet is probably kirbz - i know he built his own engine
or andyduff
Regards,
ok nice one matey
What info are you after? :)
basically all the dimensions of the rods matey exact length internal bore dimensions,thickness weight would probably be good aswell so i can copy/make my own for a start then the same for pistons after buddy
if this works i might start manifactureing them and a few other parts later on
id say it would probably be best to actual be able to look at one myself but as i am relatively new here i wouldnt want to ask anyone as you guys dont know me from adam yet lol
Well I can send you an eagle rod with a JE piston attatched to it if you want? Obviously I'd need it back (I don't fancy developing the worlds first V5 engine :D ). Probably best that way since there's so many dimensions required and I don't have the tools to measure them accurately enough at the moment...
that would be great buddy i will join up in the next 2 weeks or so that way you will know exactly where i am then matey thanks alot buddy i will pm you as soon as i have joined you are a star matey
Ok bud no worries :) Anything to help and get the UK progressing up the Z32 tuning ladder :)
and if you ever need any machineing doing let me know il sort you out if i can buddy
I'll ask John Dixon to put some info up as he has designed and had made all the internals for his VH45 lump. Slipper pistons and the full nine yards.
cheers matey nice one buddy
you might have to heat treat or stress relieve some of the internals!!
good luck with the machining fella
cheers matey thats not a problem at all buddy i have someone that can do that side of it aswell its just as i said getting the actual dimensions of them but that should be sorted very soon thanks to andy :bow: :bow:
