A couple of questions .......
Is there anyone on here that would do the two console pods with the blue led`s for me as ive never used a soldering iron in my life and would botch it just by looking at it. There would be many beer tokens for anyone that could do it :)
What price would i be looking at for someone to weld me 2 new rear arches as the owner before dafox rolled them with a ball point hammer or a bears claw :headvswal Dafox had them wax-oiled so are good for a while yet but just wanted to get a rough guess at cost to replace.
If i was to get a set of UK clocks, could i transfer my milage on mine which is in KMs to miles? Dont know if thats entirely legal or not? I wouldnt be changing it to a lower value but converting the true milage into a uk clock which would then read in miles from then on.
Brakes, this is my setup..
Brembo 3G Grooved & Dimpled Front Discs
EBC Grooved & Dimpled Rear Discs
EBC Redstuff Kevlar Pads All Round ....
But she doesnt want to stop at all, not even just at high speeds or when cold but generally its a major job stopping her without dropping a gear which makes the arse twitch. Theres no sloppiness in the pedal and feels nice and secure/tight but the stopping distance is well over what it feels it should be at. They also heat up and smell quite a bit if ive been in her for longer then 20mins.
  • Replies 32
  • Views 1.6k
Hopefully someone thats had it done will come along and let you know the costs, I think the kit is about £1k, then add another £1-2k for fitting and paint depending on what exactly you want done.
It might just be me not used to that much weight coming at you at that speed. Ill try bleeding them as shes off the road at the moment due to the engine undertray.
Excuse me for being stupid but do they cut away the standard arches and fit new wide ones? I had images of it being just a body kit so the standard arches where still underneath :confused:
Did you see my post about the seats dave? Ill will def have them off you if your dad still has them please mate.
No problem will try and get down to see the wrinklies this weekend and enquire for you.
Dave
Cheers dave.
Hope the mustangs making up for losing her :)
Dave
Fook me!!
Im scared of sitting in mine let alone cutting and hacking her like that :cry:
What a stunning finish though and was well worth it. Id have to let someone else take the job on as im no where near brave/good enough to take on a job like that.
have a gander through these, you will see what went into my wide arch kit
http://www.300zx.co.uk/forums/showthread.php?t=73908&highlight=wide+arch+progress+pics
