no power
my car seems to miss and lose power at around 2500 rpm, then backfires aqnd drives ok again
not the maf as ive changed that umpteen times
coil pack connectors?
seem ok, am gonna try getting some connectors in the next few days and try my temp sensor
mine did that but also vibrated alot and sounded like a scooby.... stopped after a while.
was told it was more than likely the MAF that got wet.
thats what mine sounds like, i dont think the maf is getting wet
well if you find out what it is... let me know!! Likewise if I get mine looked at soon... i'll give ya a shout.
1 person told me it was the maf thing getting wet, and someone else menioned loose coil thingy's and explained how to check they were all in ok... Did that but it didnt stop the scoobyness.
*touch wood* it hasnt done that again for about 2 weeks now... so im hoping it was and is nothing serious!
P.s... excuse the techincal talk! :p
Sounds like a boost leak. Check all pipework and your intercoolers for leaks or damage. You can pressurise it by disconnecting your MAF etc., and finding a good fit plastic bottle, cut off the bottom and fit tyre valve in the cap end. Fit bottle in MAF pipe tightly and pressurise to about 10 psi. Any leaks should become apparent.
looks like i will have to start taking things to bits, clean or replace
cheers for the input
