zx service garage
Where abouts in surrey are you?
Give Zen a call look them up in the traders section...they got a place off the A281 nr Horsahm...not sure what hours they are keeping over xmas though
cheers
woking near guildford
Yay :D another local hehe :D what are you looking to get done on your zed?
cheers uno
need to get this annoying judder sorted a service and it is not idling right. the cars been parked up for a while. will call zen i think :)
cheers uno
no prob
just a thought if its judder could be a coil / cylinder not firing...take off one coil connector at a time and see if the engine pitch changes when you push them back on etc
cheers
it starts happening when i brake
QUOTE=Uno]no prob
cheers
Could be one of 2 things in my experience:-
1. Front tension rod bushes worn. To fix either replace with poly or fit adjustable ones.
2. Front brake discs warped. This is caused by 15 year old calipers sticking on and heating the discs up unduly. The fix for this is remove the front calipers and fit new seals and grease up the pistons and fit new discs.
Ivan
