protoj · Tuesday at 18:48 3 days
I have just got the car back from having a poly bushing kit fitted and the rear fog lights are on all the time??. They go off if I flash the main beam but otherwise they are on no matter what!!.
Flat battery tomorrow :cry:
Cheers,
Harty.
