Seat belt
I have a problem with my seat belt. It work when you pull it out and it stops the human body in the desired fashion. What it won't do is recoil back into the door. Any ideas on how to fix this? Thanks
I have the same problem and have found that unplugging the seat belt makes it retract. Whether there is something electrical that holds the belt out I do not know sorry.
i have the same problem aswell! its an electrical fault somewhere!
i have to turn the ignition off and on until it goes back in! i hope some one knows what it is.its really annoying!!! :wack:
Nick
:headvswal
If it's a J Spec car then it will have an electric connector. Apparently it' some feature that helps you from getting your clothes caught or some crap like that. Just take the door card apart and disconnect the electrical connector on the seat belt.
Remove body :)
