need advice
car has a major missfire problem it is becoming more often as soon as it warms up
changed two broken coil packs
changed plugs
checked leads
checked temp senders
done ecu test and had code 55
any other suggestions
could it possibly be air flow meter or head gasket failure!
turbos still boosting like they should
all advice greatly appreciated before i lose all interest in this heap of junk which has cost me 3500 in repairs etc so far
simon
1990 uk tt manual
have you had in on a consult? may throw up a reason, could very much be the AFM, also could be wiring, have you pulled off the plugs from each coilpack while its running and listen for it dying a little and plugging it back in and repeating over all 6? is it over heating or are you getting any water in the oil and vs versa? you can also do a leak down test to see if its losing pressure through the head gasket?
what speed you getting the missfire? normal crusing or on accelaration?
if it was the MAF the car wont rev over 2500 ish revs
If your getting code 55 then the electric system is ok as the ecu has a memory which will come up if there had been any fault even if the fault had cleard.
I think its prob some thing mechanical ie plugs or injector etc wont be head gasket
Is it after heavy rain by any chance??
Do you have a none standard induction?
couldnt this be the ptu porblem or wiring going to it
thanks for the replies so far
i have another ptu which i am going to try rain does not affect it as it has totally standard induction.
is not using water and temp is steady
was thinking it was afm related as well but it is intermittant will probably have to buy or borrow another afm
did the ecu test which gave me the code 55... couldnt seem to get the o2 sensor test to flash anything up maybe i did not warm the car up long enough?
missfires whilst accelerating
any more suggestions most welcome
simon
simon
It wont be the AFM or MAF (same thing) as i said before if the engine revs over 2500rpm, and you would have error code 12,its possible it could be the ptu, but then you could get code 21 for ignition circuit, but take the 2 connectors off each end and give them a good clean
Sounds like the PTU to me.
It very rarely shows the fault code but depends how it failed.
In general, misfires that occur under load or in damp conditions are usually ignition related (Spark plugs, coil packs etc.)
Slight misfire at idle could indicate burned valve seats or fuelling issues and a slight misfire at steady revs (more of a flutter than a misfire) would indicate faulty EGR valve (not closing) but I don;t think 300ZXs have them?!
If your problem was caused by head gasket failure you would probably notice some of the other Head gasket problems first. (Lots of white smoke, using water, overheaating, heater not blowing hot, burning smell from engine, radiator boiling over when temp guage ok, water in the oil, oil in the water)
If you think either head gasket may be on its way out, rather than just a blow by test, get a block test done. This involves a small amount of carbon responsive liquid being held over your radiator while the beast is ticking over. If the liquid stays blue there are no problems but if there is any trace of combustion or oil in your cooling system the liquid turns yellow or green.
I wouldn't want to replace the cylinder heads without being 100% sure the gasket had blown.
If they are blown and you have to get the cylinder heads resurfaced, be very mindfull that you can't have much skimmed off them before the valves will hit the pistons!
thanks for all replies...
think i have found one of the faults
the connector to the ptu going from the right side looking from front of engine was loose as part of the locating plastic surround has or was broken so it was not seating onto connector properly i believe the last mechanic has forced this off with out working out how to
remove properly
will let you know how i get on
thanks
simon
