Really stupid question...
...but is it even possible to remove the centre panel from the rear lights without removing the side panels containing the indicators and brakelights? I've had a good look through the fog light and '99 spec replacement FAQs and haven't managed to find a definitive answer to this.
Thanks,
Bart
Sure can. Usually that's the first thing to be removed. Makes light removal easier.
Groovy, thanks. I thought I was making excessively hard work of it or something. Must just be very well stuck on. I'm starting to wonder if it's worth the effort TBH, all to make my rear fog light a little brighter by adding some reflective stuff to the inside of the bulb housing.
After you remove the nuts on the back there is a Small black push-through clip in the centre thats holding it on.
Small wet lettuce
sorry thought a really stupid question deserved a really stupid answer :tongue: :tongue: :tongue:
Hi,
Don't forget the two bolts behind the light panels, as well as the four in the centre.
I changed my centre panel the other week and didn't realise you need to remove more trim to access these bolts!
Cheerz,
Jez
