Brake advice
i think so. but wouldnt you want to know who they are made by?
eh? you mean you would be dubious because they are not a known brand mate?
Made by me chaps :)
They would fit, but they are a pain to put onto the 300zx as you need longer bolts in order for the caliper to bolt on correctly, which are a pain to get hold of :(
Dan
Made by me chaps :)
Dan
??? the calipers on the gts skyline are the same and the same fitment? so if they bolt onto the skyline they should bolt onto the zed? also the skyline gts has the same offset of the zed as well
Have a word with Mickeyb of ZworX. He's on a mission to make a 380mm kit with bremboi calipers for a very reasonable price.
Ivan
Ivan
problem with that is you need a 19" rim to fit over with a missive clearance and to fit round a 380mm disc you would need the enzo 8 pot caliper which brembo do, any caliper smaller and your just wasting disc.
IMHO 355mm is more than enough and even the 324mm brembos are good enough to stop the zed ;)
He's looking at a 4 pot Range Rover sport brembo caliper. He's got them on behind his 18's on his 'liner. He said they are the heaviest discs he's ever fitted to a road car. If they can stop a 2 and a half tonne Range Rover from 140 they should stop a zed.
Ivan
Ivan
yeh but 380mm discs physically wont fit under anything less than 19's trust me i struggled and in fact i had to change rims to fit 355mm under 18's
how much are you talking to buy, manufacturer brackets, buy discs etc? i cant imagine the new range rover brembos to be cheap?
anyway i'm at my mates tomorrow and he has the new range rover sport so i will have a look ;)
So if I get these, they will bolt straight on will they?
yeh they should do and if the bolts are too short its an easy thing to go out and buy from any place that does nuts and bolts etc
Has to be supercharged RR mate ;)
Ivan
:rofl: ;)
Hi Guys
The kit will fit, as long as you have R33 GTS-T calipers :)
The problem with the bolts, is they are really hard to find as they have to be grade 10.9 or higher and have to be M12x1.25 (metric fine). I can get hold of slightly longer bolts, but they would need chopping down :)
Dan
