help needed!
Hi....
My name is Kristinn and I have problem with my Z.
I own a 300zx two seater ´90 US edition it has 160.000 miles on it.
It has A/C, I´m having problems with the idle, when the A/C is on, the idle
is steady at 1100rpm but when it´s off it rocks up and down from 300rpm up
to 1600rmp. I have already changed the throttle position sensor and levelled
it of at 4,7 volts but it still doesn´t idle like it should. Also, when I
disconnect one vacum line in the engine it idles correctly, but it can´t be
driven like that, but when I connect the vacum line it starts rocking from
300rmp to 1600rpm. My problem only occurs when the car is idling not during
driving.
I have taken the car to a mechanic and he doesn´t know what else he can do,
is there any way you can help me with problem?
Thanks in advance, hope to hear from you soon(my car has been in the shop
for 2 weeks, and I´m dying to start driving again.
Kristinn S Kristinson.
_________________________________________________________________
Remove the AAC or IAA valve assembly (same thing), take it apart, clean it and clean the electrical connections. Hopefully that should sort it out. It's a bit fiddly but not difficult. Some useful details here www.z-car.net under the Tech links.
wsig1.gif Z32 technical article index - 300zx.org.uk
OK this sounds familiar.... What sometimes happens is that all the vac lines get crossed over and end up on the wrong pipes...
You need to get another 300 to compare all the vac lines on the drivers side just infront of the bulkhead - I have seen these crossed over before which causes the exact same problem...
Where abouts are you?
CheerZ,
Andy
Thanks guy´s for your help, and thanks Andy for the email, I managed to fix the idling and the car is working fine.Thank´s wery mutch.
Happy driving. Kristinn.
Andy, I think you should go help him out.
Reykjavík, Iceland LOL
I bet the intercoolers work nicely up there!
