rear brake upgrade advice
what have you uprated on the rear brake setup?
first option is better quality pads and discs with steel lines
or larger discs with maybe 4 pot calipers, how much and where
Cheers,
Mike :)
Pretty sure most people don't bother upgrading the rear brakes, I certainly didn't :)
Vijay
you can fit the skyline grex kit, bolts straight on and costs about £1700 for front and the same for the backs
Not much point doing the rears IMO. Once you fit bigger front brakes then the weight transfer to the front wheels under heavy braking is even greater, therefore less 'effective' pressure on the rear wheels so less grip to take advantage of increased braking force. Hope that makes sense...
