i may be fitting my apexi bovs and pace intercoolers at the weekend (bumper off i know) is there anything i need to know when fitting these ie: need to do anythng when im doing these, do i need anything extra for the intercoolers (all i nhave is the intercoolers, no extra piping)
or is there any links for doing these
cheers
Allan
intercoolers just replace standard ones using existing pipe work bud
not to sure about the apexi bovs though think they should be some silicon piping with them?
younot going to the NE meet then?
not sure, im doing this on sat, and ive got builders in my house at the moment, if they get finished on sat, i will be under my floor fitting another rad in my house :headvswal
are you fitting bov's in place of recircs? if you are then you need an extra pipe which should come with the kit which fits into the bottom boost pipe the re circs came off of
yup ive got the pipes aswell for the bovs
You may need to make new, or modify the old air ducts as the Pace intercoolers are much larger than the originals.
Yep airducts will need fabricating. Also junk the carbon canister so that some air can actually get to the passenger side cooler ;) lol
is it much to modify, (the intercoolers) ive been told they are a straight fit, aint gonna get them done this weekend anyway, but will get them done soon
Try contacting Smithy. IIRC he knows all about these things :)
Don't mean to hi jack :tongue:
Got some blitz bov's fitted in place of recircs, i used the origonal boost pressure points (one on the side of the plenum and oine on the balance bar, i think) and i know i need to bung the hole's in the intake piping but the other hose's that goes off behind the radiator, can i leave them open?? or bung them up? or do they need to be connected some how? i was told by the person i bought them off that the hole in the bottom of the bov's stays openand i dont need to connect these, is that true?
Neil
