Wheel brgs
Simple answer yes! Like most motors, New bearings will mean new bearings, second hand are usually fitted as a hub, as to extract the bearings means knackering them anyway to get them out so a complete hub will be swapped...
Im sure new rear wheel bearings come complete with the carrier with the bearing already pressed in the housing .Ready to bolt to the rear hub .
Correct, which is why they are sided as well. They are over £100 a corner iirc.
This is not what i need to hear.
Does the prop centre brg drone when on its way out?
Are you talking about these? From a 1994 TT with 35,000 miles
Thats what I mean mate, but i don't want to go spending willy nilly just to take things out of the equasion.
PM me with a price mate and I will let you know when I have narrowed it down to that being the problem.
hi
i have a prob along the same lines, how are you ment to tell the diference between prop and wheel bearings. would it be a case of running the car whilst up in the air?
rich
Wheel bearings sound like a drone from the corner, prop bearing vibrates like crazy through your arse!
If it's the prop you'll really know about it.
cheers wheel bearings its is ( the faster i go the more i have to turn up the radio)
i have to do that aswell but its from the screams and the loud exhaust :p
Wheel bearings also get louder when you go round a corner. The one on the outside of the corner.
Ivan
This is what has lead me to the conlusion its a wheel brg, when I take the load off that side, I:E go around a bend, it it almost silent.
