Bov,s/dump Valves
hi peeps,can u tell me what is the difference between them????,and do they do anything wen on an auto,see bov,s on ebay cheap,where do u fit them?????,thanks in advance guys :)
hi mate two differant names for the same thing,yes they will work on an auto but it's best to take out the recirc's and block them off ,otherwise you have two systems doing the same job,you can run both but you wont hear the bov's ,on an auto they will never sound as good as a manual as you will only hear them when you are reving quite hard then let off,as opposed to a manual, you will here the bov's when you change gear.had them on my auto,took them off and went back to recirc's,this was after i did an auto/manual conversion as the bov's caused my car to stall alot ,can sometimes happen with bov's ,anyway unless you are running over 400bhp,there is no benefit,unless you just like the sound cheers
