Conzult or Nissan Datascan
I am thinking of purchasing either of these two, has anyone had any experience with them and if so i would like to increase the fueling richness slightly is this possible ? Thanks for you help
Tom,
It is not possible to permanently make alterations to any of the maps on the ECU - for this to be possible you'd need a write function. Or, if you're feeling very flush you can buy a Zemulator from the US and hook it up to our ConZult. That way you can make permanent changes as the Zemulator overrides the ECU chip.
However, using our ConZult you can adjust various parameters on the fly and use that to create a custom map (which can then be burned to an eprom).
Dan
you can increase a/f with both of these tools, only temporarily mind. conZult is the better of the 2, but obviously is more expensive.
Thanks for your help so can i change the info on the fly then save the map and get it burnt ?
No! You can save the map with the conzult - but it will only be the stock map in the ecu - you can only make changes to the fueling and timing across the whole map by a percentage. These changes will not be saved to the map for downloading...
This is correct.
