engine stutter
well looks like another problem for the guru's the problem is when the car is ticking over runs great, put it in gear runs great, soon as you try to pull away engine stutters or ocasionaly cuts out when its on choke no sighn of problem :cry: can anybody shed a bit of light as i want to go down the right root rather than start using my guessometer cheers
Any error codes?
mine does this but ressetting ecu or resetting tps stops it doin this for about 50 miles
try cleaning the yellow temp sender for the ecu on the top alloy water pipe going into the engine, its the left connector, take connector off it prob coated in the dreaded green shit, if this is corroded it will give the ecu a wrong reading, usually does the trick
thanx lads, no error codes will try cleaning all elec connectors and see how we go
andy duff the man to see he in your manor, nothin he dont know about zeds :)
karl m8 you were spot on pal cleened connectors purring like a kitten nice one
