iv'e got an auto tt and the gearbox is slow on the upchange and sometimes wont change up at all.Its definately a sensor or a/t ecu problem.
I replaced the TPS and set it up correctly and made sure i was getting 0.45v closed throttle and 4.0v wide open throttle which it was at the plug harness where the TPS plugs in.However when i test the voltage accross terminals 34 and ground on the a/t ecu i only get 0.35v closed throttle and 2.9v wide open throttle.Now if i cut the wire that goes to terminal 34 just before the ecu connector and test the voltage it is correct,as soon as i re-connect the wire i lose some of the voltage.I thoroughly checked the pins on the connector and there is good continuity,and all the wiring from ecu to TPS is fine.So i suspect the ecu may be at fault?..Does anybody know for sure that the voltage at terminal 34 is the same as at the TPS plug 0.45v - 4.0v or is it supposed to lose some voltage through the ecu as mine does.
Cheers guys hope i'm not getting to technical and boring you all
Hi all,
Steve.....
