Cts Problem
Hi My Cts Needs Replacing But Im Not Sure If This Is The Only Prob
Is There Anyway Of Bypassing The Cts To See If I Get Out Of Safety Boost???
Any Suggestions Would Be Great
For the price of it, just get it replaced - you should have it by the weekend if you order it today.
thats cool but i didnt know if it was just the cts sensor
but it's not a bright idea to bypass an important sensor, then go out and see if you get full boost (which will heat up your coolant)... first you'll know of a problem is when you see the steam!!!!
I assume you've cleaned up the plug??
YEAH HAVE TRIED THAT BUT STILL NO LUCK ALSO THE CONNECTOR THAT FITS ONTO THE CTS IS IN POOR CONDITION HAVE USED A CABLE TIE ANY OTHER IDEAS?
Chop the connector off and fit some spade connectors that fit instead...
dont know iff you know bud but a temp sensor from a nissan micra is the same as the zed,in fact iff you ask at a normal motor factors they have them for the zed which allso fits a lot of nissans micra and zed included. hth ;)
