Safety Mode
Hi Everyone My Car Is Still In Safety Mode Can Someone Tell Me How Much Of A Performance Difference This Makes
As My Boost On Reachs 6 At The Moment But Used To Reach 7+
Am I Going To Cause Any Damage By Useing The Car Until I Get It Fixed?
I Did An Ecu Check And Its Code 13 Coolant Temp Sensor
You'll be running at 5psi and your timing will be slightly retarted. Try giving the sensor connections a good clean :)
Vijay
Wonder-wheels cleaner, a small sharp screwdriver, and wd40. ;)
bang a 1meg ohm resistor on the dett sensor plug (the bit that goes to ecu) and feel the diffrence :)
oops just seen its not dett related :slap:
