October 21, 200619 yr Hi there The revs are quite low on my car, around 500rpm in drive. How do I raise them to the correct speed?? Thanks
October 21, 200619 yr Ok check BOTH connectors (grey and yellow) at the rear of the plenum on the LHS. You're idle valve isn't working for a start (yellow) and by the sounds of it neither is your FICD (grey). FICD brings the revs up to cope with the extra load when in drive...
Hi there
