NZR escort help and advice
Guys can you help
Just bought myself a ford escort '91 1.6 carburetor model. Problem is that it isn't ideling at all, but other than that is running fine. Can you suggest any sites that I can look at or can any one offer advice.
Thanks in anticipation
Mark
Sounds like the Carb needs some Attention mate - I could try and explain but if you dont know anythiing about carbs it aint a trivial matter.
Best bet is to buy a haynes man - Only about 16 quid and always comes in handy !
Z ya
Nico91TT
Dont be a Punk ...
Please please buy it - im gettin desperate now god damit !!!
Nico
Thanks for your help, yeah the haynes manual seems the way to go, know it sounds tight fisted but want to speed as little as possible on the £400 heap!!
Mark
Mark, You could try your local Library. I know ours have most popular models for loan. Geoff
Geoff - cheers went to local library and there it was - did a search for the 300zx and would you believe couldn't find it anywere. apparently there was a copy but its been out on loan for 6 years to a guy trying to cure his erratic idle problem!!
Mark
lookin in my haynes for this car, it says
poor or erratic idle......
1/ weak mixture
2/ leak in intake manifold
3/ leak in distributor vacuum pipe
4/ leak in crankcase extractor hose
5/ leak in brake servo hose
6/ emission control system defect
7/ faulty air cleaner air temperature control
hope this helps, but as with nearly all fault diagnosis reasons, more often that not its none of the above, happy hunting..
a service for an escort would probably cost you £30, it might be worth doing that?
Mike
