what gauges?
Looking to get some gauges (4 in total) Boost oil pressure an dwater temp are the main ones but what else would ppl recomend? oil temp? water pressure?
Also who's m gauges have you got? Defi are a well known brand as are blitz, what would you reccomend? and where would you get them from?
Neil
I have the Defi setup in mine, not sure if you noticed it the other day
did have a quick loom, they're really expensive though, although they would be my first chice. i've got a blitz boost gauge that came with the car but not sure if it works, there is a hose that come from the engine bay that has a screw in the end, i assume this is for the gauge and the screw is stopping any pressure escaping.
Where'd you get your defi gauges from?
Neil
defi gauges all the way, but an average setup including boost, oil, water temp will probably set you back around £400ish
omori /apexi/hks/greddy/blitz /defi/gauges are good quality some cheap gauges give poor readings .I think on a mildly moded zed water temp /boost and maybe oil pressure are the main ones .
