Eibach springs and KYB AGX Adjustable struts
Anyone have this set up ?
What is it like ?
I think I'm gonna get a set. I already have adjustable front upper links, do I need anything for the rear for camber correction etc. or anything else ? Do you get new dust covers for the shox ?
CheerZ
PAul
What is it like ?
CheerZ
PAul
Some get camber adjusters, some dont. I think the change is that small you can get away without them.
You dont normally get dust covers with the shocks. Mine didnt anyway :rofl:
The setup is fantastic. I also eliminated the hicas. The ride is certainly harder but not too harse and the cornering is like the car is on rails. Really regained my confidence in corners with these.
Hope that helps
Pete
Ive got the same setup .. personaly id go for the camber adjustment kit as will give you more surface area of tyre touching the ground and save you £'s on tyre wear.. the springs and shocks together make the car stick to the roadn like s**t to a blanket
Universal steering rack gaitors make great dust covers. Cost me about £9 for 4 from my local motor factors.
I've been very impressed with my setup. Haven't bothered with the camber adjustment yet though.
Steve :)
'93 UK TT Manual
CheerZ all for the responses, looks like these are being bought next month then !
Is it A MUST to have the adjustable lower arms ?
at the moment I have the adjustable uppers (yet to fit) and solid poly bushes in the temsion rods
yes, it really is a must otherwise any lateral movement will kill the bearings in the upper arms
ah, but i work for an american company and my colleagues will send it thru our company fedex account as office equipment.
i am running this set-up with whiteline anti-roll bars and the full energy suspension bushing kit. I just went to the nurburgring last month and it was sweet as a nut. especially in the wet where the handling was nice and predictable on the limit. This set-up is much better than some of the comedy skateboard handling you get on coilover-ed cars, The ring in particular really shows up overdone suspension set-up. I will not be changing my set-up anymore now.
Chris
this sound like ideal kit!
how much would set, set me back in uk and where can i buy? any one recommended??
im still running origonal std suspention so its got to be knackered by now!!!!!!!!!!!!!!
