what wheel should i put my spacesaver?
I have to use my spacesaver to get my car to the garage about an hour away. I am obviously going to take it very easy, not exceeding 50mph etc but i wanted to know what side i should put it on to make the journey as safe as possible. the rears is where the power is through so i guess it would make sense to put it on the front but i am not going to be use much power so it would be better to put it on the back and use the good wheels on the front to improve the turning and braking.
The other wheels on there are 18" and the problem is with the rear right suspension (bent not broke) if that makes a difference.
sounds like it needs to be put on a trailer IMHO
I'd put it at the back. If you're going to be taking it steady, then power shouldn't be an issue. Safe steering of the vehicle is.
The space saver is designed to go on the front and the back. As long as you take it easy it shouldnt matter where you put it. If you got a puncture you cant choose what tyre is going to blow out? Just go easy. But seeing as you have got a choice do like Si says. the back.
