Does anyone know if there is a fuel line on the back of the engine?? It drips fuel from the transmission box and I can't find it... :headvswal Even worse when I jack up the front and turn on the engine :shock:
Usually the fuel leaks are around the fuel pressure regulator are you sure its not there and dripping down the back. Take off the Throttle cover and have a look beneath !
Found a fuel leak there. Let's hope it's the one... Thx
As it starts getting colder these problems will start hitting the board, happens every year :rofl:
ย
It's worth tightening up all the small fuel hoses around the plenum but especially the ones on the fuel regulator which are a very common leak point.
Another one that's unfortunately hard to get to is under the throttle cable pulley at the front of the engine.
