Strange performance any idea?
Well yesterday after coverering plenty of miles running in i thought, nows probably a good time to lean on this motor a bit and make sure its running correct under some boost!
Currently its just set at 7psi, so i give it some WOT from 3k - 4.5k, boost was good 7psi, it pulled ok, but it felt a bit weak!
Didnt think nothing of it as im used to it being at 15psi so didnt expect it to be anything too impressive but i did expect more with having gt2530s on there now.
Anyhow, later on in the day i thought, i'll give it another pop, and go a bit higher in the rpm range, so..foot down, 3k just creeping into positive boost, 4k niceley sat at 7psi, 5k OMFG!!! all hell breaks loose, rear end starts spinning like crazy, yet its still sat at 7psi? WTF?!?
Any ideas? Its like lag, but the boost is there :confused:
anyone? its a bit annoying is this did it again tonight....dont half move tho
rolling at 20 in 2nd, floor it, and i hit 70 in around 6 secs...but its not right, so weak till about 5k then it goes mental :(
