Headlamp Problem & what is the sequence?
What is the correct sequence when you turn headlights on cos I think mine are suspect?
1 turn - side lights come on, just the ones at the side low down.
2 turn - drivers side sqaure light comes on dim and round one is off
passenger side square light on bright and the round one is bright
full beam switch - drivers side nothing
passenger side square light on full and round light nothing
The light near the clocks to tell you that full beam is on (the blue one) comes on dim when turned the knob for full lights?
also the blue light goes off when you put full beam on.
Now I know this is backwards.
I have a UK car with the dip dim relay in the wing.
Fuses checked, relays checked but when I took the relay out for high beam and selected it with the stalk I never heard the one in the wing click?
Also bought 2 fresh bulbs last night still no joy.
The actual dashboard pod to turn lights on has been tested and is fine.
Sorry for the waffel :)
1 turn should be lower side lights
2 turns should be lower sidelights and both round ones
full beam = side lights and square ones on, no round ones
i think its broke. not too good with wires, etc but it sounds like a short in the light circuits? remember how fords (sierras and same age escorts) used to have all lights on one side on then the other side go off when they developed shorts in the rear?
just a thought though.
si
Just booked an auto spark for tuesday morning, hopefully he'll be a bit better than the last one. Hopefully he will say its this you daft faggot and sort it straight away :wack: :)
