300zx uk tt heated seat problems!!! please help
what i need to know is what type the relays are, iv been told the relays aer the same brown ones used for the head lights!! can anyone confirm that please? also where the timer unit and heated seat relays go again iv been told the timer sits some where behind dash on driver side and relays behind passenger side dash?? again can someone confirm that for me pleeease and one last thing as from under my carpet there is only 2 wires that come out on driver and passengr side which are for the movement of the seats! will there be a separate wire some where to connect the heated seats or will i have to sort the full wiring my self? i gess if some one can give me the wire colours that are coming from below the carpets to connect to the seats i ll be able to sort it from there please some one help me thanks
I think that you'll find that your loom is different to that of a car that came with heated leather as standard. I went down the same route as you then gave up as life's too short, and wired in 2 seperate switches.
Good luck
Jack
yeh i think im going to do that with 2 relays cheers
