clunking clutch
When I depress the clutch pedal I hear a sort of clunk. It soubds like its coming from inside the cabin as if the pedals were loose except they're not. Anyone else experienced this?
Al
not had it on the Z but sometimes automatic pedal adjusters make a clunk when they're worn. thinking of it i dont even know if the Z has one? clutch master cylinder got a loose bolt? otherwise dunno.
si.
cheers for the tip, it sounds like its coming from whateve the pedal is connected to. Afraid I dont know much about the workings of cars though so no idea what it could be.
Al
Al
when you say clunk? do you mean a constant wurring noise or does it go instantly, could be a relese bearing if so. normally a sign a new clutch is due
