hicas light
when i first start the car up the hicas light is on, then after 2 mins goes off.
whats the score with this??
cheers
:bow:
You need to top up the power steering/HICAS fluid in the big green pot on the drivers side wing.
It's Dexron type II or III automatic transmission fluid from your local garage or Halfords etc
Tends to happen more as the weather comes cool this time of year.
cheers
:bow:
You need to top up power steering fluid :)
Thats about the 20th time in a week someone has asked that question :rofl:
Not having a go btw ;)
Try topping up your..........
Didnt work for me :(
I have done a datascan check and came back with no faults (i assume it checks all sensors) Speed Sensor registered with datascan (1.2 MPH on driveway VROOOOOOOOOOOM!)
going to do a hicas diagonostics check when dry weather. :rolleyes:
At a loss.
Hope its just your fluid being low m8 :) Fingers crossed.
At a loss.
Is your steering wheel on straight or the wrong hub fitted if it's an aftermarket one?
If that was the case the HICAS light would only come on after driving in a straight(ish) line for a few miles eg motorway...
No standard hub and wheel, that was my next erm, guess but I can rule that possible fault out now,lol
