need some advice please
seen a wolf designs chip on ebay can i fit this myself???????
also just fitted a new pipe to throttle bodie as other had tear and was losing boost now the car will only boost to almost 7 but before was on 7+ does this mean im in safety mode? as the car peforms better down lower end revs now??????
dont no about wolf design chips. for any chip to be fitted your ecu would have to be socketed to do this. drop a pm to john dixon on here, quite afew people have his chips on here. myself inclued, he will fit it for you and make sure it's running right if you take it too him.
as for running in safty mode do an ecu check instrutions here
hth graeme
hth graeme
thanx mate what do u mean by getting the ecu socketed? does that mean i need to take it to a performance place?
to change the chip inside the ecu you need to remove ecu from foot well, open it up and the chip is inside to change this it has to be socketed which means that the original 28pin chip is de-solidered and female pins put in place to take the new chip, when this is done you can then have few diff chips so if you want to run a more aggressive for say track days or visits to the pod then they can be swapped over. JD can do this for you too. what are you after from changing your chip. more knowledgeable people than me might bealbe to give you better advise
how do i contact jd?
well you cant pm him,as your not subcribed, and i dont want to just give his number out. not being funny. but not my place to if you no what i mean. send me you phone number to. scubie at btinternet.com and i'll pass it on to him for you. i no he'll get intoutch with you.
hth graeme
