coolant overflow line??
coolant overflow??
Topping up my rad after a flush through and it started dripping from the bottom. I thought, "oh nut satchells I havent connected the bottom hose properly" so undid the under tray and it wasnt leaking from their but seems to be flowing through the top pipe on the filler neck (i know this to be true as i disconnected it at the top) and onto the floor. I thought this would of flowed into the expansion tank/refill tank so checked that out by taking off the seal around the passenger side wheel and it was well over the H mark so I was thinking that the expansion tank must have an overflow on it that wees out onto the under tray. Is this correct of do I have a problem? Also is there a drain on the expansion tank and how do i get to it so i can drain that aswell and replace with new fluid?
yup, the expansion tank will piss water out if it overflows
