cant find coolant drain plug - help!
Doing my coolant change and cant find the drain bolt on the engine. \iknow i can just use the bottom rad hose but want to do a full wash out. can someone put up a picture pointing it out for me please, pretty please!!
Tried to do this myself some time ago. The drain plugs are almost impossible to get to. The passenger side bolt is just above the cross member support. The drivers side is about 3" behind the alternator, which has to be removed. All i did is removed the ali coolant pipes off engine, as it was too much of a job.
Regards
Kev
