cutting out
for some reason the zed is cutting out when changing gears (down the box that is) revs just drop right off then cuts out :confused: under 500rpm sometimes surges back up to 1500rpm :confused: then drops slow to 1000-800
anyhelp greatly appreciated ;)
should have come to my meet next month, would have got hold of a datascan for ya :tongue:
got my own thanks bud :dance: :tongue:
dont know with the Z but thats a common prob on vauxhalls. its the idle control valve on them. if the Z has one of these, i'd presume it to be the same thing? if not i'd say a vaccuum pipe or pressure sensor of some kind would be at fault.
HTH.
si.
I assume your car is a TT?
If so, it sounds like you might have a boost leak. Whats your negitive boost like?
yes bud a tt
also sounds like its sucking in air from around o/s dump valve on hard pipe
cheers
anymore ideas
mine was doing the same thing ,found it to be the bov's took them off went back to recircs and put a hard pipe kit on from z centre and the problems gone ,the car also is smoother and idle is as smooth as silk,i also changed all the vac pipes at the same time,but the problem was still there untill i got rid of the bov's.
