steering
before you say it i have searched the forum. i havent got a converter. speedo works fine.
im having quite a strange prob with my steering and i dont think its the speed sensor. for over a year the steering has been intermittent. mainly worked on damp days. the speedo is fine but tonight the steering was all over the place. going from light to really bloody heavy!! i parked up and turned the steering lock to lock and the revs rised with the movement until the steering kicked out at one point causing the steering to go really heavy the car actually stalled!!! what the hell is up. also i can't find the connector to the speeed sensor to eliminate it from the equation.
hope this all makes sense.
gaz
sounds more like a problem with the pump.
are you sure the belt isn't slipping ?
have enough PS fluid in the reservoir ?
yes to both been out to check
