gearbox difference ?
does anyone know the difference between an na box and a tt ,auto or manual i need to know as i have just fried mine and need to replace .
thanks jon :confused:
if you have a TT auto..then best to put the same on .....or you can put a N/A manual box on ..but you need the prop and bit's....
i.e this for manual converstion
..Gearbox
Gear lever
New leather gear lever boot + 2 rubber boots underneath
Master cylinder
Slave cylinder
All hydraulic pipework
Pedal box
Flywheel
Pressure plate
Clutch disk
Throw out bearing
Front half of the propshaft
The plate that sits between engine & gearbox
Wiring loom for the reverse & neutral gearbox switches
Wiring loom for the alternator
Both clutch servo vacumn tanks + pipework
thanks for that nice of you to bother
cheers Jon
or you can use a TT manual box too...sorry forgot about that bit .... :slap:
Flywheel/ring gear is different on the NA and TT. If you have an NA, replace with NA. If you have a TT, replace with TT. Otherwise you'll need prop, flywheel/ringgear/starter(?)....
