rattel on tickover
rattel on tickover take revs up stop sounds like bottom crank pully ? sound like a belt slaping? any ideas not sure
u can feel it thro engine when u put your hand on top
I think ive had that problem and it was the to do with the tensioner i think lol
You sure it's not a stuck lifter? These engines are prone to them.
I had a rattle at idle that went away when revved or when I turned the engine off and on again a couple of times.
I convinced myself it was anything other than what I really knew it was cos' I new how much work it would be to sort it!
Done now though! Did it myself and job not as bad as I thought.
Ayup Sean , could be your VVT springs , they tend to weaken with age and cause a rattle on tickover , can be heard at the top of the engine , if it is, it,s not a big job and the springs are only £1.75 each from nissan HTH bud :hyper:
all right alan if it was thos id not be as consernd as i am
sounds lower down daft as it sounds could be alternator
got to work and thats wen i herd it thor crank was trying to get out
pritty shure it crank pulley rattleing wen it dose it rev it up stops then it can take a couple of mins to start rattleing again :cry:
